H20 HDMI Cable Hookup.. What cable is best?
aec4
244
I was going to purchase an HDMI cable to use with my H20 (H20 did not come with one, the installer said). When I shop for them, I see varying prices from 22.00 to 99.99. Is there a difference? What do you recommend?
There is no real world difference. Either you have a digital signal or you do not.
Here are two good websites to check. www.svideo.com or www.monoprice.com
There are however, some instances where quality of cable DOES make a difference, much like ethernet cable, any decent ethernet cable can move packets, but when the link is saturated, low quality ethernet will cause the source to retransmit data (a bad thing), causing packets to retransmit (and eating up bandwidth, creating latency (lag, like in games, etc)), digital cables are pretty much the same (except that there is no error correction), it moves 1s and 0s too, except that you will see different symptoms than with ethernet, below is a paragraph from an interesting writeup on this very subject, and below that will be the link that it's from, hope it helps.
"Cable quality, in general, should not be a significant factor in the DVI/HDMI versus Component Video comparison, as long as the cables in question are of high quality. There are, however, ways in which cable quality issues can come into play.
Analog component video is an extremely robust signal type; we have had our customers run analog component, without any need for boosters, relays or other special equipment, up to 200 feet without any signal quality issues at all. However, at long lengths, cable quality can be a consideration--in particular, impedance needs to be strictly controlled to a tight tolerance (ideally, 75 +/- 1.5 ohms) to prevent problems with signal reflection which can cause ghosting or ringing.
DVI and HDMI, unfortunately, are not so robust. The problem here is the same as the virtue of analog component: tight control over impedance. When the professional video industry went to digital signals, it settled upon a standard--SDI, serial digital video--which was designed to be run in coaxial cables, where impedance can be controlled very tightly, and consequently, uncompressed, full-blown HD signals can be run hundreds of feet with no loss of information in SDI. For reasons known only to the designers of the DVI and HDMI standards, this very sound design principle was ignored; instead of coaxial cable, the DVI and HDMI signals are run balanced, through twisted-pair cable.
The best twisted pair cables control impedance to about +/- 10%. When a digital signal is run through a cable, the edges of the bits (represented by sudden transitions in voltage) round off, and the rounding increases dramatically with distance. Meanwhile, poor control over impedance results in signal reflections--portions of the signal bounce off of the display end of the line, propagate back down the cable, and return, interfering with later information in the same bitstream. At some point, the data become unrecoverable, and with no error correction available, there's no way to restore the lost information.
DVI and HDMI connections, for this reason, are subject to the "digital cliff" phenomenon. Up to some length, a DVI or HDMI cable will perform just fine; the rounding and reflections will not compromise the ability of the display device to reconstruct the original bitstream, and no information will be lost. As we make the cable longer and longer, the difficulty of reconstructing the bitstream increases.
At some point, unrecoverable bit errors start to occur; these are colloquially described in the home theater community as "sparklies," because the bit errors manifest themselves as pixel dropouts which make the image sparkle. If we make the cable just a bit longer, so much information is lost that the display becomes unable to reconstitute enough information to even render an image; the bitstream has fallen off the digital cliff, so called because of the abruptness of the failure. A cable design that works perfectly at 20 feet may get "sparkly" at 25, and stop working entirely at 30.
In practice, it's very hard to say when a DVI or HDMI signal will fail. We have found well-made DVI cables to be quite reliable up to 50 feet, but HDMI cable, with its smaller profile, is a bit more of a puzzle. Because the ability to reconstitute the bitstream varies depending on the quality of the circuitry in the source and display devices, it's not uncommon for a cable to work fine at 30, 40, or 50 feet on one source/display combination, and not work at all on another."
Hope it helps. At the very least, it is an interesting read.
Source (under, "The Role of Cable and Connection Quality"):
http://www.bluejeanscable.com/articles/dvihdmicomponent.htm
Disclaimer:
I make no guarantee, implied or otherwise, to the accuracy or efficacy of the information found on that site.
EDIT:
A point of clarification, this is not to say that a quality cable HAS to be costly, inexpensive cables can be as high quality as an expensive cable, if not higher,
I just bought a 6' (probably could have dealt with 3', but decided to get 6' to be safe) from monoprice for 11.70 shipping priority mail! How can you beat that? It'll be at my second home before I am!
I also purchsed an HDMI cable from monoprice and it was awsome. I have always purchased Monster brand and paid out the you know what for it. Never again. Monoprice usually offers two version of their HDMI cables. I chose the more expensive one of the two but it was still under $20
HELP with HDMI
Help--Any one with philly locals and H20
