H/H Motor For P* ???
kb2kir
182
Norwich, NY
Hi, Guys.
I have a CS-6000 receiver. (Yes strangely enough, I am using it for FTA.)
As you know it will control an H-H motor. I have a spare P* and I want to try my hand at hitting as many Ku sats as possible.
I want to purchase a good one as I do not want any trouble with it.
People have done Primestar dishes on SG2100 motors with some modifications to the bracket on the P*
Since its heavy the best thing to do is remove the bracket on back and fabricate something. I know people who have posted it here before :)
Otherwise a HH120 would work with it
Sadoun was mentioning a newer model motor that handles heaver dishes and has metal gears the DG280
its probably a bit more in price but should handle the weight
on my old setup i modified the mount to work with the sg2100 and it worked fine. but at the ends of the arc seemed to strugle a bit ( plus i had to use 1.2 for both ends of the arc).
there is also a mini review in the review section from stogie about the GS120 from Sat AV sounds like the mounting bracket is a bit beefier than the sg2100..
LNB's for the T90
More RTN Subcarriers announced
