Hello! I'm new to this forum as well as to C Band.I was given a 7.5 KTI mesh dish and plan to install it for C band only.I have not done a 'string test' on the dish yet but it appears to be in excellent shape.No loose panels,tears.or holes.The dish doesn't even need paint.Some surface rust on the circular mounting ring that will need touching up and adding pole to replace what I sawed off.
The dish will be 120 ft from the house.I will use a ground rod/ground block at the dish and another ground rod/ground block at point of entry at the house.Both will be bonded back to the house main ground as required by code.The question is: Do I still need the 'messenger' wire ground on the coax,or will just coax suffice ?
Next: Am I correct that the RG6 must be solid copper core rather than the cheaper copper clad?
And finally a 3rd question: How much will I be limited by the smaller (7.5) dish size? I wish to receive stations like Grit ,MeTV,network channels and Spanish channels like Univision and Telemundo.I'm in a bad area for OTA and this dish will be my main source of live tv.
Thanks for your assistance ! I'm sure I will have more questions after I get the pole up.Lots of landscaping, grading, and digging to do before then though.
I have researched these forums for days and here is what I have or plan to get based on what I have read.My income is limited but I'd prefer to do it RIGHT the first time.Any advice on purchases is much appreciated.Thanks!
KTI 7.5 polar mount mesh dish
Super Jack 24" (Untested to date)
C1-PLL C-Band LNBF to purchase (Possibly a dual output to connect a second tv)
Motor control wires to purchase
VBox to purchase
RG6 coax to purchase (Would prefer RG11)
GeosatPro MicroHD OR Amiko Mini HD SE to purchase (no interest in IPTV.Use a Roku3)
VBox to purchase
