Which is best for humid environment on mast (using Copper ground wire) galvanized steel strap or copper?
The power meter ground is about 50 foot away, I was going to go to 8' rod by mast and separate 50' line from rod to meter, is this OK?
https://asgmt.com/wp-content/uploads/pdf-docs/2005/1/F8.pdfThe power meter ground is about 50 foot away, I was going to go to 8' rod by mast and separate 50' line from rod to meter, is this OK?
IIRC, it doesn't matter whether the wire is insulated or not. It does need to be protected from corrosion and physical damage. NEC 250.64(B) is a tricky one.YES provided that the antenna rod is bonded to the entrance rod via a buried #6 bare copper bonding jumper
