Ok, one other angle - your incoming cables from the dish are not properly grounded. Check and see if the line from the dish itself is connected to a ground block anywhere and the ground block is then connected to the house ground.
The Dish cables are the same they have always been and there never was hum before the 622. The only thing new besides the 622 is the 1000.2 but it is mounted on a plywood mount on a asphalt shingle roof, the same as the dp500 that it replaced. All the wiring is unchanged since day one 8 (I think) years ago. and through all those years and four prior receivers and three dishes there never was hum.
I know you guys are the pros but remember I didn't say anything about a ground loop. I just said I have hum. Ground loops cause hum but so do defective power supplies.
What about this, if it is the coax from the dish then the hum should disappear if I disconnect it. Wait and I'll try it....
No luck. Without a dish connected the hum is the same.
This does give me an idea though, I'll just disconnect everything connected to the back of the 622 one at a time and see if there is a path into the 622 that is carrying the hum (or is causing a ground loop)
Since this thread has run as long as it has and only two of us have hum on their 622s (and one is sure it's caused by a ground loop) then there is a one in a million chance I'm unlucky enough to have the one 622 with an internally caused hum.
