Thanks for the pics Auric. Mine does not have the square tubing. Mine has the three thin round tube braces. You can see it in the pictures here.
I am going to custom make a bracket then then use the same kind of LNB holders you are using.
Tron, for now I am going to try mode it for C-band, but if I ever use it for just Ku, I will definitely use the feedhorn and just replace the LNB.That appears to be a C-120 flange mount on the feedhorn, although it could possibly be one of those weird mounts that is similar but has a different hole pattern. If it is a C-120 (probable), you would just unscrew the Norsat LNB from the mount and replace it. That is a Prodelin 1.2 meter dish...
