gonna try and reaim
hort22
34
my 129 signal is horrible...actually i cannot get any HD to come in...what sat and transponder should i be on when reaiming my dish...any help would be great
on the sat: you answered your own question.
select the lowest transponder, if you improve that, likely you will improve the rest.
yah i am moving the elevation screws and it improves a bit but only for 1 transponder...the rest are still at zero...i cant even pull in ESPN HD and that should be an easy one to pull in...should i mess with the skew or stick with the elevation part of it?
if this dish was working before, at this location, there should be no need to adjust the skew.
so, was it working well before? did a tree brach grow in the way? little leafy's come out and block 129?? what changed??
it worked fine on my house until the trees grew in...a former dish employee and i moved to a pole in the backyard about 2 months ago...signal was ok until this week...with hardly no hd coming in
How are you signals on the other sat locations? Several of the HD channels (ESPN for one) are on 110, not 129.
give me a sat and transponder and i will check it out...i mean some sats that should be good reception...
never mind just shot the elevation a bit higher and i am getting in the 50's...better than no HD i guess...
Did you verify the dish is adjusted correctly? It seems odd that you had to raise it a lot in order to get a usable signal strength.
not if the pole isnt level any more for some reason. lawn mower hit? kid hanging on the arm? etc? etc?
Are RSN's covered in Dish HD Absolute pack
How many dishes for one 722 and one 322 installaton ?
