Going to switch to Directv, Wiring Question
afail
Pittsburgh
hello
I am going to be getting Directv and signing up for the package that offers the free HD DVR. In addition, I will have a regular HD box. I am going to be wiring my new house for cat 5 and was wondering what (if any) type of connections the satellite boxes require?
hello
Directv rec's connect with RG-6 coax, also might want to get Compression fittings as they are the current connection being used.
? You know that D* does basic installation free, right ?
If you have other runs that you might want to run your self, that's fine too, you can probably skip the fittings and the D* guy would probably be happy to connect them for you, seeing you've already ran lines he would not have to run .
Yeah I know it is free
I want to run Cat5 through the walls and mount plates. So it is Coax only? I thought the boxes needed internet connectivity
I know with cable they would run you lines but would do so in a poor quality..
They don't need the internet but you will want to connect them so go ahead and run the Cat-5 as well as the Coax. They won't run it the way you want it without charging you for it. With the Cat-5 from your router to your DVR you will be able to use VOD.
DirecTV North
Want to Switch To Directv, need help with costs
