Some old business:
I've got an FM transmitter tower about 1.5 miles away and may need to do something similar.
Depending on the location and the antenna setup (of the FM station and yours) that could, if strong enough get through the nooelec filter there Brett. It may need a FM filter as well.
One sure way to see that would be to hook up the SDR in place of the GRB receiver and tune to the FM band, If the FM signal is stronger then the GRB signal then you could have problems. Same for in the cellular bands.
During the late morning into early afternoon is when I would notice a little higher rate of sync errors.
A reminder that anybody that uses satellite services should know this. That at certain times of the day the satellite gets eclipsed by the sun. Meaning the sun is almost or is in line with the satellite so the result may cause loss of data or even loss of signal lock.
KWX signal issue most likely is not related to that.
Though since the filters he may have solved it.
With that taken care of..
Thanks for the complements
Looks is one thing as long as it works well is what will count, looks can be improved later.
Just make sure the aluminum tape is making contact, I don't know if the adhesive would cause to be that much of a barrier but if it is, then you will have a poor circuit for shielding. Use the OHM meter to determine this.
I checked mine and (where I didn't tape it) found a low resistance path so it's the way I want it.
If it shows "open" or very high resistance, you need to redo it.
I'm using a solar panel to power my LNA outside
A solar panel should be a fine supply but make sure that it don't have any ripple on the DC.
Most likely there is a battery in line so that "should" take that away. Ripple is an enemy of the feed electronics and can cause all kinds of issues that result in data errors. Same is a bad filtered wall wart.
I am still sidelined -- I developed pneumonia after the flu. It's not fun, but I will probably survive.
Take it easy and watch yourself, this flu has claimed several lives. Stuff is nasty this year.
It would easily pass as a 'bomb'. Let's see, do we cut the red wire or the blue wire?
LOL,
There is some truth to that comment.
It involved the bomb squad and a ham radio balun in Omaha. It would seem that ham radio baluns are considered dangerous when in or on PVC pipe....
You can probably find the story on the web somewhere.
I won't put anything on here.
Got the new (used) computer, Win 7 Pro so as of tonight I got GRBStreamer on it and GRBDump as well along with the TBS5927 driver.
I see what you said about the streamer there Brett, for configuring it.
Maybe this weekend I can test it all but it's going to get cold again and windy, with all the snow melt that's happened it's a muddy sloppy mess around the dish now.
