As a part of introducing the new ESX521U-AM adjustable Ku band LNBF, I'd like to do a free giveaway to someone who can test and report the results and do a review on this new LNBF. Please keep in mind that if you win, I'd like to see you test it and post the results and the review within a reasonable (a few day) time after receiving the LNBF if possible.
As far as I'm aware, there is no adjustable monoblock LNBF available in the North American market, so this is a first. This unit will replace our old WS24 LNBF brackets that we stopped producing.
So here is what you do in order to enter to win the ESX521U-AM LNBF:
Reply back to this post with a combination of satellites that range between 4° to 12° that you would think you may be interested in picking up with the ESX521U-AM. The more the better.
The drawing will be held on Sunday the 24th of July, and shipped on Monday the 25th. Please make sure you enter no later than Sunday, the 24th of July by 9:00PM PST. Good luck everyone
Technical Specifications
Input Frequency Range 10.7 - 12.75 GHz
L.O. Frequency 9750/10600MHz
L.O. Stability 1 MHz (-40 - +70° c)
Ouput Frequency Range 950 - 1450 MHz
Noise .2dB typical
Conversion Gain 60dB typical
Input VSWR 2.5:1
Output VSWR 2.0:1 (max)
Connector F Type female
Impedence 75 ohm typical
Cross Polar Isolation >25dB (min.)
Image Rejection 45 dB (min.)
Phase Noise -50dBc @ 1 KHz
-75dBc @ 10 KHz
-95dBc @ 100KHz
Supply Voltage
Ca: 11.5 - 14.0 V = Vertical Polarization
Cb: 15.5 - 19.0 V = Horizontal Polarization
Operating Temperature -40 - +70 degrees Celsius
Storage Temperature -40 - +80 degrees Celsius
Relative Humidity 0 - 95 %
Throat Diameter 40mm
Noise .2dB typical
Input VSWR 2.5:1
-75dBc @ 10 KHz
-95dBc @ 100KHz
Supply Voltage
