If these sound like a n00b question, its because it technically is.
I am in an area that i have zero experience with and there seems to be a secret handshake/password to get in mentality here, so I guess I will just ask again where I hope someone will help a virgin.
I have readjusted my Toroidal to see from roughly 87W to 129W. I am trying to fine tune it to make sure I have 87W on the far side - so I can pick up PBS-HD.
Thus far I appear to be on the arc properly with 129W - 91W circular coming in properly. That part I am very comfortable with.
However, the lnbs on the low side are a bit off where the sweet spot should be so I am concerned that I might not have enough room on the arm for 87W.
I purchased a DVBWorld USB to receive PBS-HD, but have no idea how this works.
As I am getting strange signals on my meter all over the place between 101W and 91W....even down to the end where I suppose 87W should be, I am a little more concerned. So I thought I should try and see how the DVBWorld USB unit really works before I try to see if I can actually receive 87W.
Thus I have found a really strong signal between the lnbs for 91W and 101W (yes this is a linear lnb).
Its about 1/2 way over so I assume its probably Intelsat Americas 5 or Galaxy 3C.
So I install the newest DVBWorld USB software.
Reboot, start DVBWorld and it says I have a signal of 74% and a quality of bouncing between 0 and 22)????
Go to configuration, leave Type as Fixed, set SAT to Galaxy 3C. Set lnb to Universal (I assume this is correct). Do not check 22KHz Tone, Tone Burst and disable DiSEqC.
Hit scan (looks like it starts at 18 and only goes to 22, only Horizontal????????)
Finds nothing that I can tell.
How can I tell what satellite I am really on? How can I at least find out if this is working properly?
As I don't know the secret handshake or passwords, I guess some think their exclusive club doesnt deserve outsiders.
Would anyone that doesnt think their s... doesnt smell bother to tell me what I am doing wrong or how to test this out for the first time?
