When I set up my motor, the best thing I did was first aim at true south, then aim at something on the far end of the arc to the west and to the east and tweak ever so slightly on your elevation, and maybe even move your lnb by hand on the arm of the satellite just a smidge to tweak signals from the 30s to the 60s or so on the weakest of tps. Eventually after enough tweaking, you'll basically get all the bolts to line up to as good as you are going to get. When that happens, you might just tweak on one bolt or whatever til you are satisfied and are getting the full arc. Always, no matter what, make sure you have a level on your pole when tweaking to make sure you don't accidentally nudge the pole out of level in any direction too... and keep an eye on that bubble as you work so that it stays that way. a cheapo level from wal-mart with a magnet on it should do the trick.
