volkodav said:sounds like you have 2 dish 300. you may have to get dish 500
What you mean. What differentiates DISH300 with DISH500 ?. What else I need for DISH500 ?
I will explain what exactly I have...
1) Antenna1 -> Where I have single LNB which I use for intenational channels and i am getting correct signal for 61.5. Direction for this antenna is quite different. This portion seems to be workig fine
2) Anenna2 > It says Direct TV Channel Master. I have hooked up DISH PRO TWIN LNB and one of the Coax canbel coming in from Antenna1 in IN port. I have another two OUTPUT port and one of them is not used and another is going in DISH 311 receiver. This Antenna should have Y Adapter but as of today I do not have it so I have hooked up one of the portion in pipe where old single LNB was.
I thought DISH500 means you have DISHPRO TWIN OR DUAL LNB and you get 110/119 signal on this.
Correct me where I am missing
