mande
hutch401 said:the matter of the receiver losing time has been an issue with me for some time.
The transponder time is correct on both transponders.
Corrective measures are to return the receiver to the default Glorystar settings:
- Make sure the OTA Automatic Update is set to ON
- Perform an OTA "Update Now" to be sure your receiver has the latest firmware
- Make sure the Time Setting is in the default Automatic Time Setting mode. The time will drift if you are setting the time in the manual mode.
- Any time that you wish to force the receiver to resync the time setting via the satellite (if in the Automatic Time Setting mode), place the receiver on channel 1,2,3,4,5 for 10 - 15 seconds.
Quick question for clarification... IF THE RECEIVER stays on 101 for example, does the auto time setting still work correctly?
