GEOSATpro CK1 C/KU LNBF and DiSEqC switch help
wildboys
328
I have the GEOSATpro CK1 C/KU LNBF and i am trying to hook it up to my motor.I have a 2 way switch my motor has a lnb connection and a receiver connection.How can i connect the motor via the 2 way switch to the GEOSATpro CK1 C/KU LNBF.Do i connect the lnb in of the motor to the receiver input on the switch and connect the to coaxial outputs of the GEOSATpro CK1 C/KU LNBF to port 1 and 2 of the switch and connect the receiver coaixial to the receiver connection on the motor?
put the switch inbetween the LNBF's and the motor.
So:
Motor's "receiver" goes directly to receiver.
Motor's 'LNBF" port goes to the switch Input.
Each LNBF port goes to #1 or #2 on switch.
Make note of which LNBF goes to what port so you can set the receiver accordingly.
So:
thanks i got it to work
Buzz receiver and AC3
Montana PBS at 90% :)
