I finally got around to installing it today on my 7.5 foot Perfect 10 dish....My notes are as follows.
If you have a tripod arrangement, you'll be fine. If you have a quad leg, like I do, you'll be short a screw to attach the scalar ring to the fourth leg. And NO bolt I had would fit. I had to use a smaller bolt and just tighten it real well. Other than that, no install issues.
Adjusting it, however, was not so easy. Not a fault of the LNB, however, I just couldn't hold the LNB and watch the TV screen to see the SQ at the same time.
Skew...man I scratched my head almost until it bled...I couldn't get both polarities to skew right. Turns out ( thanks to an earlier post by Iceberg I found here) the LNB needs to be at the 9:00 position to start and THEN you set the skew. NOT like a KU LNB, this one does NOT install 0 Degrees up. Once I did that, everything fell into place.
Signal quality was better than my Chaparral feedhorn/Eagle Aspen 25 degree LNB combo, so no complaints about that. I probably gained 5-8 points on the Coolsat 5000 on the typical TP. Very satisified.
I ran the two outputs into my attic, installed a 3X4 multiswitch, and bam, C-band on every receiver in my house!
Thanks to Our Gold Sponsor Satellite AV for a great product at a great price! :up:up:up
Pics are below....first one is what I started with, then after that as I installed it.
