I forgot. We have a cold front stalled on top of us with sun and thunder and rain clouds right there so to speak, and now it's almost dark. I'll check for voltage Brian. I can't do it now but I'll try tomorrow between rain.
What LNBF are you looking for?
Should have a small quantity of the CK1s with PLL KU section on Monday.![]()
If the LO frequency had drifted on the old LNBF, the transponder frequencies may be incorrect if they were previously scanned in.
Did you delete the old transponders and blind scan after installing the new LNBF?
Glad that fixed it for you! Nice write up - looking forward to those pics!It turns out I was right, it was too early to call. It was still having problems when it warmed up in the daytime. I took the whole sensor board out and made a magnet wheel and used a glass reed switch. I thought and looked at it, and thought some more about how to encase and mount the reed switch. I was over engineering it a bit at that point.
The glass reed switches look like a resistor so I just bent the leads (very carefully) into the right shape to put the ends right under the screws where the sensor wires go. It's bent so it stands out and up under the wheel just right! I used a seasoning salt lid to make the wheel, one of the bigger ones. Just cut the threaded part off and you have a perfect size disc. My Von Weise has the optical wheel and the 1/4 shaft sticks up through it a bit, just enough that I made a hole in the disc and forced it on. I didn't need glue or anything and it's a nice tight fit and holds good. The optical disc braces it a bit too from the bottom.
I used six 3/16" dia. x 1/32" thick N52 magnets from K&J Magnetics. These here: http://www.kjmagnetics.com/proddetail.asp?prod=D301-N52
I glued them on with dollar store rubber cement and they're on there good. I tried slightly larger magnets that were 1/16" thick (N42 & N52) but the switch never opened. They were 1/4" dia. x 1/16" thick D41G-N52's and something a bit smaller than that but the same thickness. The thinner 1/32" ones were just the right strength. I think the width played a big part of this too. N42 & N52 are the strength ratings, the site explains it. There is a lot of cool info there.
The ones I used are very thin and strong and it doesn't miss a count, none, and I haven't had any errors! I linked them above but they are D301-N52's if you look them up by model number. The optical wheel had six slots and six magnets works great. When it was optical I couldn't get it to move by a 1 count, almost never, it'd jump 2 no matter how fast you hit the button. Now it'll count one at a time easily and consistently! Now that I've done it I could make one and install it in a half hour.
It works really good and time will tell if it's missing counts and getting out of sync but I just don't see how it can now. I wish I'd have done this before I ever put it on the dish, it's that good. I have a new Freesat V7 on the way, a new C/Ku LNBF from Brian and a dish that goes where you tell it and I told it to go a few places!
I'm guessing the optical sensor was the problem and it didn't crop up until it had been warm for a while. I installed it in the winter and one day it just went goofy. It was hard to pin down the problem. It would fake you out and make you think you had it fixed when it cooled off but then go goofy when it warmed up. When it rained it cooled off and it worked but I thought it was possibly getting water somewhere, took a while to soak in maybe. Nope, it was heat!
I found all of the info about where to get the magnets etc here in the forums. I also read that 10 or 12 magnets really doesn't noticeably help your resolution. It turns out 6 magnets fits and works good and it's so easy to do, I used all hand tools. I cut the disc out of the lid with a pocket knife and used a file to round the edges and smooth them. Then I just made a hole in the center, slightly smaller than the 1/4" shaft.
I used forceps to grip the lead on the reed switches right up next to the glass, very close to it. If you put pressure on the glass while bending the leads you'll break it so use the forceps! Needle nose pliers are not narrow enough to let you get the leads bent the direction you need them to go and have enough lead left to fit under the screws. Grip it tight so it doesn't turn and form it in sort of a U shape so it'll stick out and up at an angle when you put the ends under the screws. Tighten them down and you have it mounted! Once the cover is on it nothing can break the glass and it works great and is easy to change should you ever need to. Glue your magnets on the disc and force it on the shaft and you're good to go!
I have a nice camera and will get some photos of it posted. Photos will make it much easier to understand what I'm saying and it'll make perfect sense.
I got this 10 pack of reed switches for $3.24 total and got them in 3 or 4 days. When you order the magnets you'll see $15 shipping or something and I almost over looked where you click USPS and then you get $5 S&H. I have a few spares that are too big for this job, but I'll find something to use them for. My friend's 5 or 6 year old son swallowed some that he got from a boy at school and it messed that boy up! Keep them away from children, they stick their intestines together and it's a bad, bad, deal. Emergency surgery and all because the kid lied for days and just said he had a belly ache. Anyway, this is so simple to do and it flat makes it work. It's a two wire system now that the Gbox is compatible with and likes!
And I want to say thank you for all of the help Brian and Magic Static, Lone Gunman, and a couple of others who posted magnet wheel projects. I can't remember who all it was, but it was several. In my case just putting the switch leads under the screws is the way to go. No glue, no tape, no solder and no hassle. It just fits and works. I'll try and add the photos tomorrow, just have to pop the cover off.
Here are the switches: http://www.ebay.com/itm/371323460047
