I tried to reply to an older post dealing with this topic, however, it would not let me post since the article was too old.
For those of you who noticed significantly lower signal quality levels when G19 went live, have you noticed any improvement or the levels still the same for you?
I have had the same issue since G19 went live and nothing I have done has improved the signal quality. For example, my signal quality on TBN used to be in the 40's and 50's. Now it is in the 20's and 30's. Most of my other channels on G19 are in the same range. Channels on AMC4 are great and have always been so with no quality fluctuations. I have changed the switch, swapped LNB's, installed all new coax, checked for dish warping, checked for a level mast, factory reset the receiver, fine tuned overall pointing of the dish and adjusted the LNB's. I am in western Maryland if that helps.
I would appreciate feedback from those of you who have had the issue and would like to know if things improved for you or not.
Thank you very much.
