My 1H/1J installation went quickly and well. Once everything checked out, I asked the installer to insert the diplexers back in line, so as to avoid having to go climbing once they released the OTA module. It seemd to work OK, so I sent him on his way.
Well...The system worked fine for a while. BUT, the Joey started intermittently losing connection to the Hopper, eventually not being to locate the Hopper at all. And, when I set them both to pop-up notifications for Moca, both units popped up low signal warnings.
I removed the diplexers, and full signal was restored. No pop-ups. No searching for other devices. This doesn't bode well for the future of the OTA module. Even if they do release one, or update the Hopper to be compatible with off-the-shelf usb tuners, it may very well mean running a separate cable(s) from the antenna.
