kslates said:
I have a 57" Sony TV rear projector and I just got 1 3room system on Saturday but my picture is really fuzzy and isn't clear at all. I got the Directv d10 receiver. Is it my TV, cords, or receiver that is messed up? What should i do? Thanks for your help
First of all let me say I disagree with everything that has been posted in relation to compression. This is simply NOT TRUE. Yes the signals are compressed, however, kslates likely has a poorly crimped connection or a pinched cable somewhere in the chain.
I currently have DirecTV, Comcast Basic and OTA setup on my 55" WS RPTV and DirecTV is far superior to any of these mediums except for the DTV OTA transmissions.
Kslates, providing you have a wide screen TV, try shrinking the picture to 4:3 ratio for SD viewing. In line with what I said above all programming looks somewhat grainy on 16:9 TV's unless, you do this. It is because you are stretching the image to fill your screen. There are in fact defects in all programming signals (including digital) and these effects are blown up the larger your screen, the worse the problem. However, stretching the image from 4:3 to 16:9 only makes it worse.
If your TV is 4:3 and not 16:9, I would first question coax crimped connections, pinched or bent cable, then dish alignment, then line of sight (LOS) issues. If you can provide in your next post your dish type, location, cable routing, cable length (guess) and other details you may think of, that will help.
Compression does play a factor in image quality, I am not disputing that. I am only saying that this is not his issue. There are millions of us watching and if the picture was that bad not only would we have cable but D* would never quit getting calls (like Voom). I personally play with this 2 years ago when I went WS, because I was like WTF!??! Believe me, the images on my 55" WS RPTV are just as good now as they are on my 24" Sony Wega.
