what are the differences between different sizes of dish? I know that 30" is the minimum dish size requirement for FTA, but whats with the bigger sizes?
The oval dishes have a focal pattern that is smeared out to pick up multiple birds. ....
...... in my measurements (Wave Frontier T-90) was only down 3 dB around +/-20 degrees compared to a prime focus (Fortec 1.8m) at +/- 7 degrees and a normal offset (GeoSatPRO 1.2m) at +/- 3 degrees.
Thanks.
In reading this though, I was trying to imagine how you took these measurements? Did you measure the signal while centered, then move the dish the indicated angles off center, then hunt for the position of the lnbf that gives you best signal? That's the only thing I could come up with, and that seems reasonable with the torroidal, or prime focus, but it seems like it would take quite a bit of searching for the best spot with an offset. Or am I missing the obvious (as usual ).
I'm curious where you've read this {ie about the smeared focal pattern}? I have assumed that elliptical dishes are just elliptical sections out of a regular paraboloid {which will naturally have a smeared pattern for any lnbf not at the focal point}, basically no different from a regular dish with respect to only one focal point. If, in fact they are not paraboloids as it sounds like you're saying, I'd be interested in reading more the theory involved.
In any event, regardless of design, it is my opinion that any time you put more than one lnbf on a dish, it is a compromise from the start, because there is only one focal point of the dish, and any lnbf that isn't at the focal point will have reduced performance. Seems to me that smearing out a focal pattern would make the dish a complete non-performer, as it wouldn't have ANY focal point.
It's also my assumption that on multi-lnb dishes, that since the lnbfs are designed for an F/D based on the height, that each lnbf will only illuminate a portion of the dish consistent with a circular dish with the dimensions of the height of the elliptical dish, and the focal pattern of any off center lnbf will be smeared, and and be less efficient than the center lnbf.
It's obvious, however, that despite the obvious reduction in performance, that many people are having good luck with these multi-installations, although I really wonder, just how good the interferrence rejection is, compared even to a circular single lnbf dish with a height equal to the height of the elliptical or torroidal dish.
Anyway, just my opinions, and I'd welcome opinions to the contrary, particularly about those torroidal things, which I've never understood very well.
I recall reading about the Superdish design while working for DN as a technician, the shape is neither truley parabolic nor elliptical, but a mixture of the two in order to maximize the signal delivered to each lnb, while minimizing the adjacent satellite inferference. The focal pattern looks like sideways hourglasses. I assume some serious math boys did the calculations and that mass producing them cheaply was a main consideration.
Are you just getting started and have no equipment? If so I'd recommend finding a free dish network super dish, DirecPc dish or primestar dish. Place a wanted ad on craigslist or freecycle. You can find receivers on ebay for about $30. An install kit with all your wires and ground block is about $20 (ebay). For $50 you will be receiving fta ku band on one satellite. Enjoy it for a while.
Then start reading and read some more on this forum. Eventually you'll be craving a better receiver, a bigger dish, switches, c-band,....
Now that you are hooked and have a case of techno-lust come back and visit the sponsors. They've got all the fta-crack you can handle.
