(This is my second try to post, the first time it was dropped because of the url I had embedded. Now I removed them. Sorry if it double posts.)
First, congrats on your site, its great.
I have been looking for a few months now before purchasing my ku linear equipment.
I purchased:
-Fortec Star 100cm KU Band Offset Dish w/ Fortec Single LNB.
-FSKUVN Fortek Ku Universal LNB
-Viewsat Pro
-50ft RG-6 cable (tested on my working Expressvu service (equivalent of dish network in Canada))
-12 inches tv set that I bring outside
Here is my issue. No matter what settings I put in my viewsat and no matter where I point my dish, I always have no quality and I have always a signal strengh between 73% to 79% never below that even when I make a 360 degree. My lnb power is on.
When I connected everything I made sure to connect/disconnect my lnb only when I unplug my vspro.
My Satellite pole is level and plumb. I made a factory default on my viewsat. I dont have a switch connected on the system yet. I dont have a ground cable yet. I set my satellite to 95W Galaxy 3c (because it is in the viewsat sat list after a factory default) and I wanted to have a high one for initial setup (I thought it would be much easier).
I looked at dishpointer dot com (url removed) for my elevation, azimuth mag, lnb skew. I set my elevation on the dish kit that came with my antenna (fc-110). I align the lnb center with the dish holder and turn the lnb 4 lines (20 degre) clockwise when standing behind the dish (as dishpointer says).
No matter where I point my dish, I get at least 73% signal. I never ever have quality. If I move the dish (slowly as recommended by Iceberg 1/8 inch at a time) sometimes I will get as much as 79%signal but still quality remains always at 0%. Since I have a Universal lnb, I set the lnb freq to 9750/10600. I checked the list for the tp freq in my viewsat setup and they match to what is listed here (url removed) the list .
At this point because of the signal behavior, I suspect my lnb to be DOA. Before going back to the store for a replacement, I want to know what you think it might be. Also, do you think I would be a much better to upgrade my lnb to a big white 50$ ku lnb (I dont have the details now but the store rep told me that it was the Cadillac of lnb's). I want to get the Atlantic birds for french channels:
Name: 34.5W Intelsat 903
Elevation: 25.2°
Azimuth (true): 131.4°
Azimuth (magn.): 146.6°
LNB Skew [?]: -31.7°
Name: 97.0W Galaxy 19
Elevation: 32.7°
Azimuth (true): 211.4°
Azimuth (magn.): 226.6°
LNB Skew [?]: 21.5°
Thanks all.
PS: I wanted to have all pertinent info. Hope I didnt miss anything.
I purchased:
-Viewsat Pro
Elevation: 25.2°
Elevation: 32.7°
LNB Skew [?]: 21.5°
Thanks all.
