I just bought Fortec Star FC-80cm dish.
Before I go on the roof and install it, I looked on all the parts and the installation instructions.
I used “d!shpointer.com” to get all setup data for my location.
I have couple of questions:
Setting elevation and LNB skew seems to be easy.
I’ll appreciate any suggestions from all of you that had and solved this problem.
- How do you set the azimuth: to “true” or to “magnetic”? The logic suggests “magnetic”, since I use compass. Am I right?
- How important is the accurate azimuth setting? Having just a small compass and mounting the antenna on the slanted roof it is almost impossible to aim the antenna and fastening the bottom mount pointing precisely on, for example, 213.6 degrees.
