Found this earlier today. For those of you wanting to jump ship cause you thing Charlie is dragging his feet on HD or for those of you who already have left Dish for Directv because of their promises in all their ads, all I can say is HAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!
DIRECTV Not Likely to Add HDTV Soon
The satcaster probably won't boost its high-def lineup until this summer.
By Phillip Swann
Washington, D.C. (March 22) -- DIRECTV is currently running a TV commercial promoting its plan to offer up to 1,500 High-Definition TV channels. However, if you're a current subscriber, it may be awhile before you see any additions to the DIRECTV HD lineup.
DIRECTV now carries seven national HDTV channels, in addition to high-def feeds of the major networks in selected cities. However, the satcaster is not expected to offer any new HD channels until this summer, with the possible exception of one or two. (And don't even bet on that.)
The reason: Lack of satellite space.
Starting late next month, DIRECTV is launching four new satellites over the next two years that will enable it to provide up to 150 national HD channels and local HD in most cities by 2007. (The 1,500 high-def channel number in the commercial is referring to the total number of local high-def channels DIRECTV will deliver by 2007; viewers will not actually get 1,500 HD channels. They will get their local channels in high-def and DIRECTV's national HD channels, which could be 150.)
But until the first satellite is operational, which could be as early as June, DIRECTV simply doesn't have the capacity to boost its high-def offering. (Adding a high-def channel requires more satellite space than a non-HD network.) DIRECTV plans to use that first satellite this summer to provide high-def feeds of local channels in 12 cities.
To illustrate DIRECTV's limited capacity, the satcaster has announced that it will eventually add the high-def version of ESPN 2, which launched in January. However, sources tells TVPredictions.com that DIRECTV may be forced to wait until late summer or early fall before it can add ESPN 2 HD.
Adding to its HD woes, the satcaster plans to use the MPEG-4 compression technology with its new satellites. Consequently, current high-def owners will need a new dish and receiver to get the local high-def signals this summer and, eventually, all high-def channels from DIRECTV. The satcaster has yet to announce when the new dish and receiver will be available, or if it will offer the new equipment at a discount or no cost.
By Phillip Swann
