For Sale: 2 Prodelin 1.2M Ku-Band Receive/Transmit satellite dishes.
Both dishes are 1.2M (48”) Ku-Band Receive/Transmit antennas and were used in transmit/receive situations before being retrofitted with the receive only feed arm and LNB’s.
The LNB's have been capped off on the threaded end so as not to let in moisture and they have remained clean and free from corrosion.
The feed horns both have the clear plastic protective covers intact. No rips or holes.
Both dishes are set up to simultaneously receive both the horizontal and vertical polorization of a Ku-Band feed.
Dish 1 is fairly new and the cleaner of the two. It will accept a mounting pole up to 3.5 inches in diameter. The back of the dish looks like a Prodelin Series 1123 but could be an 1134.
Dish 2 is a little older and dirtier. It will accept a mounting pole up to 3 inches in diameter. It is NOT a Prodelin Series 1125. Maybe an older Series 1123?
Asking $180 for both.
Contact Cory at coryjon(at)gmail(dot)com or phone 425-205-0969.
Dishes are located in the Bothell Washington area.
I would prefer not to ship them.
