Hi All,
I finally got a chance to setup a GEOSATpro 90cm I purchased about a year ago with a GEOSATpro SL1 and I'm aiming at Galaxy 19 (97W). Currently using a Sonicview SV-8000HD that was given to me by a friend who no longer uses it.
I got the LNBF skewed about -21 degrees and I can get almost all the TP's (Q 38-51) except for one, which is 11966H. I can barely get a Q of 25-29 on it and I get no video and broken-up audio while attempting to tune into channels located on the TP (e.g. The Word Network).
I have a feeling that from my location, 11966H is *the* weakest TP to tune into and I've tried my best to lock it in with a better Q and just haven't had much luck. Now I'm starting to wonder:
#1. Is my LNBF bad in general since it seems all my Q's are relatively low (Highest Q on a TP off Galaxy 19 is 51.)
#2. Is the LNBF arm munged up during shipment so that my LNB isn't at the focal point?
I've changed out RG6 and I was using a short run anyway for pointing. The dish doesn't 'appear' to be warped and I haven't done the 'string test' yet which I will later this week. The mounting-mast *is* plumb.
... So this leads me to believe that possibly the LNBF/SL1 isn't at the correct focal point of the dish. And I realize this is an 'off-set' dish, but is there a way I can figure out, other than sliding the LNBF back-and-forth, what the proper distance is for the LNBF to be from the dish?
Thanks in advance!
Cheers,
Kermee
Thanks in advance!
Cheers,
Kermee
