just installed my slimline using sat 101 as my meter (directv setup) - install went smoothly and 101 signal strength is strong but goose eggs on 99a, 103a and 103b. the mast is plumbed perfectly (according to the level bubble) so i'm thinking it's just a matter of using the fine tuning knobs to dial in the other sats.
while i was tuning the dish i did notice that i was able to turn each fine tuning knob several times without weakening the 101 signal - as such i'm thinking that if i now use 99 and/or 103 as my meter (instead of 101), slowly turning these knobs will result in signal strength/variations for 99/103 without impacting 101.
but before i tackle this i'm wondering if a seasoned pro might let me know which setting i should play with first - the fine tuning knob for elevation? the fine tuning knob for azimuth? or perhaps i should start with tilt? i'm reluctant to start with tilt or course elevation/azimuth because i did notice that slight adjustments to these settings does impact my 101 signal strength.
btw, should i even be seeing signal readings other than zero on sats 99a, 103a and 103b? is their activity on these sats/transponders? any help would be greatly appreciated!
here's what i have:
101 - 32 total
01-08: 090, 095, 093, 100, 093, 100, 091, 098
09-16: 095, 096, 095, 100, 095, 100, 094, 100
17-24: 095, 000, 094, 100, 093, 098, 094, 098
25-32: 095, 000, 095, 000, 095, 100, 093, 100
110 - 3 total
01-08: ___, ___, ___, ___, ___, ___, ___, 097
09-16: ___, 095, ___, 096, ___, ___, ___, ___
17-24: ___, ___, ___, ___, ___, ___, ___, ___
25-32: ___, ___, ___, ___, ___, ___, ___, ___
119 - 11 total
01-08: ___, ___, ___, ___, ___, ___, ___, ___
09-16: ___, ___, ___, ___, ___, ___, ___, ___
17-24: ___, ___, ___, ___, ___, 000, 092, 093
25-32: 069, 096, 095, 095, 094, 096, 089, 096
99a - 14 total
01-08: 000, 000, 000, 000, 000, 000, 000, 000
09-16: 000, 000, 000, 000, 000, 000, ___, ___
99b - 16 total
01-08: 095, 000, 095, 000, 093, 000, ___, ___
09-16: ___, ___, ___, ___, ___, ___, 000, 000
17-24: 000, 000, 000, 000, 000, 000, 000, 000
103a - 16 total
01-08: 000, 000, 000, 000, 000, 000, ___, ___
103b - 16 total
17-24: ___, ___, ___, ___, ___, 000, ___, ___
here's what i have:
101 - 32 total
110 - 3 total
119 - 11 total
99a - 14 total
99b - 16 total
103a - 16 total
103b - 16 total
