Finding Pointing Angles
mbarnes
I have a dish on my RV for traveling. It only takes me a few minutes to set it up. Normally, I get my aiming angles using my GPS and a program on my PDA. However, I arrived at a location recently to find the batteries dead in my GPS. So, I was going to try the old fashioned way, plug the zip code into the receiver (4700, yes it's old, but they won't give me an upgrade, even after seven years :confused: ) and get them there. Much to my surprise, the screen has changed and there is no box to enter the zip code. Just a note that says "For aiming angles, go to www.dishnetwork.com." Fortunately, I was able to get on the Internet, but I went all over that lousy dishnetwork site and never found anything about aiming angles. I finally found some batteries for my GPS and did it my way. Ah, TV at last. However, what about all those who don't have my resources for aiming angles? Why are they no longer on the receiver? Where exactly are they on the web site? What about travelers who don't have Internet access on the road?
It seems E* has a thing against RVers.
there is a program called sat finder. do a google on it and you should find it. all you do is install it and run it. when you run it enter the zip code of where you are at and it will give you the elevation, azmuth and skew if needed for where your at. (this bad boy tells you every sat out there and tells you where in the sky it is in corrispondance to you. that should help you out. but you might have to refer to the point dish screen to get the skew for 110/119 that applys to a dish 500. Hope this helps
522 freeze and crash
? about HD on 129
