Well....
Dude came back today to finish. For a while I was afraid he was flaking out on me but he did finally finish up.
So anyway..
The hole for the the BIG dish, the other day he tired out and stopped digging. He came back the next day and did the cement for the first hole (for the 6' dish) and stopped.
He took Thursday off and then today came back and finished digging the 2nd hole and put the pole and cement in.
Problem though, he could not dig any deeper than 4'. The plan was for the hole to be 5' deep. But the handles of the digger were hitting the sides and he couldn't get any deeper and couldn't pick up any more dirt. He had hit the physical limit of the hand diggers.
We stood there and discussed it and he insisted that the pole was not going anywhere. I wasn't convinced but there really was nothing else that could be done without renting a machine and taking days more time and even more money. So I made the decision and told him to go ahead and plant the pole as it was.
I got out of the way and let him do his thing.
He ended up with the hole 4' deep but it was slightly bigger around than the other hole and took 11 sacks of cement (vs 9 on the other pole).
I ~hope~ that this will be strong enough to keep that 10' dish in place through storms. Not that I have any choice in it...
I had really hoped that he could put the thing 5' in. Oh well..
So now the poles both ended up a lot taller than I expected.
The small one, it's 6' out of the ground. The big one, is 7' 8" out of the ground.
I'm thinking they are going to need to be braced up somehow. I don't know..
Anyway, after he finished the cement I got him to put the 6' dish on the pole.
So the little dish is up there now and much closer to being able to actually work than ever before.
But, I have no idea what my next step is. I guess I need to figure out how to put the motor on it. The other problem is the lnb. I have an old c-ku lnb but it has a motor in it that changes the polarity. I have no idea how to make the motor change. I have no idea how to mount the lnb in the dish. It can be slid closer to or further away from the dish in the ring out in the center. And then which way to rotate it??
Then there is aiming the dish. And the motor. I have no idea how it goes on. Or how to adjust it.
Right now the dish is just sitting on the top of the pole like a wilted flower with nothing connected. I need to figure out my next step now. I am now into something that I have no knowledge of.
I do know this much. I want to aim this small dish at satellite 87w, I think it is an AMC satellite. I want to get This TV and MeTV. I won't complain if I can get Nasa too.
I know that both of those channels are on horizontal channels.
That should mean that the lnb won't need to change polarity.
To get it adjusted to the right spot I can use the gbox (which I have no idea how to use either). Once I get it aimed at the right place I will remove the gbox and I can connect the lnb to the 8way switch just as if it were another ku lnb. Right?
I can assign a switch port to that dish/lnb just as if it were a ku dish. It won't be motorized at all for the time being so that should make it easy once it's set. It will more or less stay aimed at 87 for the foreseeable future. The 10' dish is the one that I plan to fully motorize. I'm still weeks away from that happening.
I guess now I need to plow through old threads on these little 6' dishes and try to figure out from the pictures how you guys put the motors and lnb's on them. I'm ~hoping~ to be able to start watching stuff on 87 Cband this weekend.
