That will never work unless a scaler is added to the mix, and even then I wonder how the scalers deal with HDCP 2.2.
Please don't take this the wrong way but my quoted post refers to my OLD setup. I am living proof that is how the setup was working & it did.
The splitter was non HDMI 2.0 + HDCP 2.0 compliant. The HDMI cable from the H3 to the splitter wasn't compliant, either. ALL three TVs worked in 1080 but the 4k set did not receiver 4k. These are facts. It worked in this way.
When I used a known HDMI 2.0 + HDCP 2.0 compliant HDMI cable directly into the 4k TV, bypassing the splitter, 4k was present on channel 146 & 148-01. I did not change any of the setting in H3 to do this. The Samsung 4k set indicated it was now receiving UHD 3840*2160 @ 60P. This is also a fact.
Using the compliant HDMI 2.0 + HDCP 2.0 cable as an input this time, instead of the older HDMI that I thought might be compliant as before, absolutely nothing passed through the splitter. All that happened was the splitter's LEDs blinked indicating an incomparable signal. This is also a fact, too.
I gather from this experience that H3 technology detects total compliance of all HDMI cables & TVs used.
The best you can ever hope for is 1080 on all 4 sets when viewing an HD source and 4K only on the 4K set(s) when viewing a 4K source.
Yes. But be aware of this I found this morning from a seller of the splitter I purchased,
"Hi Derg, when you use 4k Samsung TV,please connect the TV to output1, then the output signal will be HDMI2.0 /HDCP2.2.But when you wan to use your 1080P TVs,disconnect the 4K TV and connect one of 1080P TV to output1(plug in again),signal will lower to 1080P and output to 2 TVs simultaneously.(AV Access Team)"
I'm sending the unit back. It didn't work as was described in the sellers response until I swapped the compliant HDMI 2.0 + HDCP 2.0 cable for the same older cable that did work with the old setup. This is no good to as I'm right back to where I began.
I know only the 4K set works for 4K sources, but I'm still not 100% clear what happens for HD output when the 4K is connected to port 1. Do all sets work?
If you can get 4K source on 4K sets only and the rest of the time get HD sources on all sets without having to muck with cables, I'd call it a success.
If not, then a switch to switch between the splitter an direct to the 4K set would be a better choice.
Also, what (if anything) does the H3 output on the component ports when the HDMI is pushing out 4K? If the component output is hot with a 1080 version of the output that could be the answer.
Component is analog so 1080i I believe is max, isn't it?
I don't see a work-a-round worthy of doing. I'll do things manually when wanting to watch the other sets.
