thebigjp said:The answer to this question alone will determine how heads spin.
Heads will spin, or heads will roll. Slight difference.
Or, god forbid, you could have those same 12 SD channels with better picture quality than they had previously, plus add a few more channels to that transponder to boot (just not 24 new ones).Scott Greczkowski said:8psk is not only used for HDTV, it can be used for standard def too!
Now imaging if you have 12 SD channels on 1 transponder, with 8PSK enabled they could put 36 channels on a transponder with no worse picture quality we have today.
David_C said:The downside is that it will probably take awhile to replace all of the old receivers that don't have 8psk capability. I think that makes it more likely that 8psk would be used for new HD channels.
Totally untrue - it's help to add 33% onlyScott Greczkowski said:8psk is not only used for HDTV, it can be used for standard def too!
Imagine if 1 HDTV channel took 1 transponder of satellite space, however with 8psk they can squeeze in 3 HD channels on 1 transponder, with no loss of quality.
Dish is now putting 8psk in all of its boxes. Even the 111 has 8PSK built in.
"8PSK it's not just for HD anymore!" (Sounds like an orange juice commercial!)
Smith said:Totally untrue - it's help to add 33% only. Not the 300%.
That last argument point is just plain stupid. Who the heck pays extra for the receiver, extra for the programming (or maybe OTA for free), and hooks it up via a modulated SD signal? If you really have to have channel 3 or 4, go get a RF modulator at Target for 20 bucks. 99.9% of the people who get this receiver wouldn't even miss the lack of modulated signal.boba said:Dirk you should be able as a new customer to get the Hughes E-86 for less than $500. No I don't expect it to be $199 but I know it works unlike the 811, it is available unlike the 811 and it offers ch.3/4 output unlike the 811.
silversurfer01973 said:Nice link. IMO not any uglier than that Voom box...![]()
mike123abc said:33% more bandwith does not sound like much, but when you consider that DBS satellite slots are a very limited resource it makes it far more valuable. DIRECTV has 46 transponders, this is like getting 15 more... enough for 30-45 HD channels.
This is especially true with HDTV. DIRECTV can only fit 1 HD channel/transponder now with QPSK, unless they start compressing to fit 2. With 8PSK they can fit two whole HD channels at the full 19.2 mbit/sec. They can put three HD channels on 8PSK with less compression than the 2 on QPSK would have been, plus the odds are better that all three channels peaking at the same time are less than just two peaking at the same time.
