Fail
sasgenesis
Purchased system from GoSatellite/FTA direct they direct me to you Guys
Not receiving any channels on any satellites, only receiving "FAIL" on all channel searches.
package:
Dish 30" fortec star,
Coolsat Ku-Lnbf rf11.70/12.20ghz; IF:950/1450MHZ lo:10.75GHZ
rotor sat hh90, stab-usals and diseqc1.23 compatible viewsat2000.
Site installation is in Santa Monica, CA USA Lat 34N, Long 118.5W,
Dish elevation 39.5 clear sky no obstructions, plumbed rotor head, motor is responding
-have experience in installing Dish networks systems successfully
Installed dish and receiving 70-75 signals receiver processed the searches then received Fail and no channels
Downloaded current software from viewsat and installed into receiver
Newer software allowed for USAL Set up
Input my site lat./longitude etc.
Still receiving signal of 70—75
Tried USALS and manual searches always receive fail, still no TV channels or radio
Any suggestions? Really stumped.
Welcome to the SatelliteGuys.US FTA forum :hatsoff:
I always recommend you remove the motor from the equation and find and store a few satellites (True south) before adding the motor. I know its not what want to hear but its always a good idea to walk before you run. If you feel you are close to a satellite try a blind scan, then you will know where you are in the arc.
Code:
                   Santa Monica, CA 90405
          Latitude 34° 0.600'N Longitude 118° 28.302'W
                        Sat Name Sat Lng Az(t) Az(m)    El  Skew
                    Intelsat 901   18.0W 264.1 250.0 -17.0 -55.5
                    Intelsat 603   20.0W 265.2 251.1 -15.4 -55.7
                           NSS 7   22.0W 266.4 252.3 -13.8 -55.8
                    Intelsat 905   24.5W 267.8 253.7 -11.8 -55.9
                    Intelsat 907   27.5W 269.5 255.3  -9.4 -56.0
                  Hispasat 1C/1D   30.0W  90.9  76.7  -7.4 -56.0
                    Intelsat 801   31.5W  91.7  77.6  -6.1 -56.0
                    Intelsat 903   34.5W  93.4  79.3  -3.7 -55.8
             AMC 12 & Telstar 11   37.5W  95.1  81.0  -1.2 -55.7
                         NSS 806   40.5W  96.8  82.7   1.2 -55.4
                       PAS 6B/3R   43.0W  98.2  84.1   3.3 -55.1
                          PAS 1R   45.0W  99.4  85.3   5.0 -54.9
                    Intelsat 705   50.0W 102.4  88.3   9.1 -54.0
                    Intelsat 707   53.0W 104.3  90.2  11.6 -53.4
                    Intelsat 805   55.5W 105.9  91.8  13.7 -52.9
                           PAS 9   58.0W 107.6  93.5  15.7 -52.2
                        Amazonas   61.0W 109.6  95.5  18.2 -51.3
          EchoStar 3 & Rainbow 1   61.5W 110.0  95.9  18.6 -51.2
                Estrela do Sul 1   63.0W 111.0  96.9  19.8 -50.7
                    Brasilsat B2   65.0W 112.5  98.4  21.5 -50.0
                    Brasilsat B1   70.0W 116.4 102.2  25.5 -48.0
                Nahuel 1 & AMC 6   72.0W 118.0 103.9  27.1 -47.1
                       DirecTV 5   72.5W 118.4 104.3  27.5 -46.8
                           SBS 6   74.0W 119.7 105.6  28.6 -46.1
                           AMC 5   79.0W 124.2 110.1  32.4 -43.3
                         Nimiq 2   82.0W 127.1 113.0  34.7 -41.4
                           AMC 9   83.0W 128.1 114.0  35.4 -40.7
                    Brasilsat B3   84.0W 129.2 115.1  36.1 -40.0
                          AMC 16   85.0W 130.2 116.1  36.8 -39.3
                           AMC 3   87.0W 132.4 118.3  38.2 -37.7
             Intelsat Americas 8   89.0W 134.7 120.6  39.5 -36.1
                Galaxy 11/Nimiq1   91.0W 137.1 123.0  40.8 -34.4
                    Brasilsat B4   92.0W 138.3 124.2  41.4 -33.4
                       Telstar 6   93.0W 139.6 125.5  42.0 -32.5
                       Galaxy 3C   95.0W 142.2 128.1  43.2 -30.6
             Intelsat Americas 5   97.0W 144.9 130.8  44.3 -28.5
                       Galaxy 4R   99.0W 147.7 133.6  45.3 -26.3
                           AMC 4  101.0W 150.6 136.5  46.2 -24.0
                           AMC 1  103.0W 153.7 139.6  47.1 -21.6
                          AMC 15  105.0W 156.8 142.7  47.9 -19.0
                         Anik F1  107.3W 160.6 146.4  48.7 -16.0
        DirecTV 6 & EchoStar 6/8  110.0W 165.1 151.0  49.4 -12.3
                         Anik F2  111.1W 167.0 152.9  49.7 -10.8
                   Solidaridad 2  113.0W 170.3 156.2  50.0  -8.0
                        SatMex 5  116.8W 177.0 162.9  50.4  -2.5
         EchoStar 7 & DirecTV 7S  119.0W 180.9 166.8  50.5   0.8
 EchoStar 9/Intelsat Americas 13  121.0W 184.5 170.4  50.4   3.7
                      Galaxy 10R  123.0W 188.1 173.9  50.2   6.7
                       Galaxy 12  125.0W 191.6 177.5  49.8   9.6
            Galaxy 13/Horizons 1  127.0W 195.0 180.9  49.4  12.4
             Intelsat Americas 7  129.0W 198.4 184.3  48.9  15.2
                          AMC 11  131.0W 201.7 187.6  48.2  17.8
                       Galaxy 1R  133.0W 204.9 190.7  47.5  20.4
                          AMC 10  135.0W 207.9 193.8  46.7  22.9
                           AMC 7  137.0W 210.9 196.8  45.8  25.2
                           AMC 8  139.0W 213.8 199.7  44.8  27.5
                    EchoStar 1/2  148.0W 225.4 211.2  39.5  36.1
        Satellite Finder is (c) Copyright 2004, P. Lutus
Your true south satellite is around 119w Use a DirecTV/Dishnotwork LNB+Receiver point to 119w and you are done! Use an L.O. of 11250 if you use this LNB. Then switch back to the KU LNBF and change the L.O. back to 10750.
Not to be an ass, but I recommend you buy from someone who will actually try to help you instead of sending you to a internet fourm. Again, no offense to you, but same thing happened to me with a Twinhan card. Bought off ebay, card is bad, contacted Twinhan, no response, contacted ebay seller, said to look on internet.
Ebay Sweetness
This LNB
