Bec factory defaults
Thank you for your reply Peter.
You wrote a frequency number, vertical polarity and a S/R number. Is S/R the symbol rate? I see on the lyngsat site the numbers that you listed. It seems to be related to only one channel named Pittsburgh International Telecommunications. Is this only one channel or is this a group of channels that you watch?
As for me, I would like to watch middle east channels. Would I have to enter the frequency and S/R numbers for each of the ones I want to see? For example, RANG-A-RANG TV NY, but this has s/r of 60. Would I have to change s/r to 60? Also, some of those channels don't even have a S/R listed.
Is it going to pick up those without an S/R number that are listed under the 20765 S/R?
I only see the frequency number and S/R and polarity under the channel search screen which is under the setup menu. When I go under satellite setup there is a whole bunch of satellites listed there and T5 is one of them. When I go to the channel search screen I can select satellite Telstar 5 and it displays frequency 11749 and 7232 for S/R with vertical polarity. So if I select a different TP on this screen I can select the frequency 11836 that you use.
So, I'll have to select a different TP to select the different frequencies and S/R for each group of feeds/channels? Then I'll have to scan and it will pick up all the channels on that frequency? Is this what you mean by setting up my Telstar 5 again?
Mohammad T.
