I initially tested my new(ish) 3 meter solid with the C band LNB that came with it. I intentionally left all the setting the same since the move was only a 1/4 mile and had been working at that sit since installation in ~'90s until about 6 years ago. About all I did was rebuild the actuator which had been filled with mud during a flood several years ago. However, the feedhorn and LNB only had a few dead bees inside. I replaced all the old coax and control cables. I was able to receive a couple C band sat. channels on a very difficult anolog receiver. Signal quality was low but I could get a sharp black and white picture.
Next I installed the Corotor II Plus from my old(er) 10' mesh dish. I left the scalar as it was on the old dish and the "d" at the same distance as the original feed horn.
The reception was about the same as that of the original feed horn C-band LNB. Still no color and no Ku band. (In retrospect I don't think I ever got any Ku on my old(er) mesh dish. In fact I'm having about the same problems that I had on the mesh BUD).
I calculated the d distance and the f/D ratio for the solid BUD with the Corotor and here are my numbers:
D = 101.5"
d = 15.875"
f = 40.56"
f = ratio = .3996
I set the focal distance to 40.6 inches and set the scalar to .40
Now I get almost nothing on either C or Ku band.
Since I had nearly the same problems with my other dish, I'm wondering if I should look into replacing my LNBs. Especially the Ku since I have never receive any signal on either dish.
Please look a my math and see if I have been doing something wrong.
Comments and opinions welcomed.
Steve
D = 101.5"
d = 15.875"
f = 40.56"
f = ratio = .3996
Steve
