ok this had me wondering about how much a program takes up on the hard drive so I was going through some routine organizing (ie: deleting) and here is what the hard drive showed after each program
Started with 35 hr 1 min in HD 140h3m in SD
Removed a 37 minute MPEG4 HD program....35h10m 140h39m
Removed a 30 minute OTA HD program (720p channel)...35h15m 142h00m
Removed a 1 hour OTA subchannel program (480i channel)...36h06m 144h24m
Removed a 1 hour 2 minute MPEG4 HD (MLB Net)....36h18m 145h12m
Removed a 3 hour SD program...37h7m 148h29m <-----this solidifies that the SD amount is set for a MPEG2 setup
Removed a 2 1/2 hour MPEG4 HD program...37h38m 150h33m
so when all said an done
SD amount is for SD MPEG2 satellite programming
HD is about 5:1 ratio....5 minutes of HD sat programming = 1 minute on the hard drive space
HD OTA is about a 2:1 on HD
SD OTA must vary depending on the bandwidth of the subchannel
I guess I'll have to run some more tests
