As everyone knows the bracket for directv dishes are too wide to put bolts in all the holes when placing it on a fascia.
That wasn't a problem with the smaller dishes but on this slim line 5 LNB it is!
I Put up the bracket and had it plumed but when I installed the heavy dish it went out of plumb because it pulls on the fascia.
I can't use the arm (pole) that came with it to install it directly to the bricks because it's not long enough to reach the same height as when it's installed on the fascia.
Do they make a longer arm??
I really don't want to use a pole cemented in the ground.
At present I have a 2X4 jammed in behind the bottom of the bracket and the brick wall. it's still a half ball out of plumb but it works.
Herb
Herb
