I acquired a Prof 7300 card and have had excellent results with 32 bit XP SP2 installed on 32 bit machine. Using a Tektronix digital scope with a breakout box on the lnb input the Diseqc transmissions are as expected. Dvb Dream has been the application used and the PROF drivers were the original 1.1.0.4 version.
When installed with 32 bit XP SP3 on a 64 bit machine results are not consistent. The Diseqc transmissions are seldom present. The bda.log file shows they were sent but the scope does not trigger (single sweep recording with either plus or minus 250mv level ). Tests with the 22Khz were also made. Once in a while something shows up.
I have updated the bios and all the motherboard drivers on the 64 bit Gigabyte mainboard to no avail and am using the latest online drivers version 1.1.0.5 after originally trying the 1.1.0.4 version.
While PROF limits the operating system to being 32 bit there is no mention of such a limit on the hardware requirements.
A friend is getting the PROF 7500 USB version which I hope to evaluate on both machines.
