Everything is level and pointed to the right.
psu190
13
Hey guys, hopefully you can help me out. I live in Hawaii so it's hard to get an installer over where i'm at. So i resorted to trying this on my own. Bought a 24" voom dish to try to get the 119. Made sure everything is level, the mast and the base. Called dish told where to point and bought a compass to help, but nothing is coming up, read that I should have it on the 11 transpoder to get the best signal strength.
I'm using a "Y" yolk on the end of the arm to convert the square to the "D" type of dish pro. Should I get a "I" adapter instead since the lnfb will be in the middle instead off to the side.
I would call dish to come out and setup but it would take 3-4 weeks for someone to get out.
Anyhelp would be great, if not thanks for looking.
RLB190
I would recommend getting the I adapter if it will fit on the Voom dish. Best to have the LNB in the center, but off to the side should work too. But an off center LNB would require several degrees of compensation when aiming the Dish.
Things you might want to try:
1) Have you done a "Check Switch" yet?
2) Are you using magnetic or geographic north on your compass? You should be using geographic north. They can be up to 20 degrees apart.
3) Are you using an LNB that is compatible with your receiver?
4) Are you using RG6U cable? It should be UHF rated RG6.
Hope this helps.
1) I did a check switch and it says "lnb status: direct connecct to a dp-dual, dp-dual2 good connection, no signal. So I assume everything is good.
2)Not sure about the compass, it's metal case liquid filled lensatic compass, liquid filled. Doesn't say anything else about what kind it is.
3)Yeah it's a dish plus dual lnb that is connected to a dish 301 receiver.
4)It is rg6 cable and rated uhf.
Even bought a cheap sf-95 sat finder to help me out, what good that thing does/did. The thing reads like it gets a sat signal but nothing on the screen. Strange..
Thanks though for suggestions.
rlb
I just looked it up and the compass magnetic declination in Hawaii is 10 degrees. This means that your compass needle points 10 degrees east of true north. Some compasses have an adjustment where you can set the declination. If it doesn't, then you'll need to aim your dish 10 degrees west of where the compass tells you.
That combination should work fine.
I ordered an sf-95 myself yesterday (probably wouldn't have done that if I had read this first)! Oh well, it was only $11.95. Now I know why.
Have you tried using the "Point Dish" screen, instead of the sf-95 meter? (This might require a portable TV on your roof, a long power extension cord, and a composite video cable).
RLB190
The Yoke adaptor is your problem. When you added the Yoke adaptor you changed two things. The Focal Point point on the Dish is at the end of the Mouning arm (The Yoke Adaptor mounts both LNBF's off center which works with a Dish 500 but NOT a One Slot 24 Inch Dish) so your LNBF on your Yoke Adaptor is Off Center as well as outside of the focal distance.
The I Adaptor will NOT work either as you will still be still be out of the proper focal distance.
I will suggest two things;
1) Get a 24 Inch Dish with a "D" Tube.
2) As long as you don't Need a Dish Pro LNBF (I assume you are not using a Dish Pro Plus Switch) then just get a Standard Square Ended DBS LNBF.
John
Yes, if the focal distance is wrong it will not work.
If you know what the focal distance should be for the 24" Voom dish, then you might be able to use a hack saw to cut the metal arm to the correct length.
But it would probably be easier just to get one designed for Dish Network. They are not very expensive and used ones are in abundance.
I'd get a square tube D* LNB. The 301 will see it as a legacy. Those are cheap, and in abundance. You wouldn't even need to run a check switch, just clear that stuff off, otherwise you might get bogus error messages.
I just learned that the azimuth angle given in the "Peak Angles" screen is relative magnetic north, not geographic north. So please disregard my post here where I said you would have to compensate by 10 degrees.
Any luck yet?
I had the following problem when Installing a Dish myself.
I had everything set perfect, and I kept getting the same message: Good connection no signal.
I ran another check switch, same thing.
Then I exited out of the screen and went back through the menus again and went to point dish screen, and
WALLA! I was able to find the satellites and peak my dish.
Try that
Once the signal strength screen is showing:
get the dish pointed in the general direction, and just start moving it around.
yeah, you wouldn't even need to do a check switch other than to clear out the matrix, since there will be no switch to check. If you do run a check switch, it should show up as a legacy dual.
dpp 44 switch
Which dish to put back?
