Error Message
rsmith3400
19
What is this error--"attempting to logon to xm website error xmo102
Sounds like you have the wrong user name and password in your XM Radio Online settings in the software. The settings are filled in on the configuration window (right side - middle).
In Authentication Server I have---xmro.xmradio.com
In Data Server I have---player.xmradio.com
Anything wrong with that?
Those are correct and are the original settings for the software. You're failing the logon which would mean that something you put in the two spaces above that (your online account information) is wrong.
I'm using the same exact login and password as I use for xm online. That should be right.
Try going to the XMRadio Online website and logging in. If you can get in there but not in TT, then you have something wrong with TT which may require some fixing.
http://xmro.xmradio.com/xstream/index.jsp
If you cannot log in on the XMRadio Online site, you'll have to contact XMRadio and have them fix your log in info.
XMRadio Online website works fine. In fact, because TT has been down (for 2 months), I bought Total Recorder, and have successfilly recorded from XM. TT has the problem. I just bought Total Recorder yesterday, so that is not the cause.
Changed to a new xm in car receiver
directories saved to and duplicate files
