Error code 48-341 C41w client Troubleshooting
A-BOT
Earth
Have a Genie setup with HR 44, 2 Mini Clients, 1 Wireless Client with Video Bridge. New coax ran to receivers and swm. They connect with 8-way green lable splitter. Extra terminal terminated. Bridge 10 ft from HR44, 20 Ft 1 wall from c41w. Signal connect shows green with good to excellent strength. C41w takes pin to connect then stalls or comes back with Error code 48-341? There is no outside antenna or any other signals being combined. Any help with where to start? Bad bridge or receiver? Im Stumped.
PS All wired clients and HR 44 work great.
Code 48 means a network interference issue, but as I remember there are other things that can cause it. Do you have three client licenses?
Take a look at the MAC addresses or names provided under the error code, this will let you know what is failing. That error codes indicates that a MOCA node(s) is getting a weak signal. Wonder why you have an 8 way with only 3 receivers?
How long are you cable runs?
The OP says his bridge is 10ft from the HR44 (how many feet from the splitter?) and then the wireless client is 20ft (thru one wall) from the bridge.
Is the bridge next to any other wireless transmitter?
YouTube Application No Longer Available via DIRECTV
Free At Last, Free At Last....
