Duplicate channels
cousineddie
30
SW Wisconsin
How to do I get rid of the duplicate channels in my Favorites for HD? It shows the 6000 HD lineup and also the same ones in the lower numbers that are also HD. I've had this problem for awhile since that last update and now its really getting annoying.
Well, you can disable the downmapping if you want (go to the local channels menu item).
YOu can also lock out the higher numbered channels in the locks menu. But be warned the search features will not show the results for the low mirrored channels in the lower channel range. IT is the same for the hd locals too. You have to keep both in the menu or the search features won't work . It is a flaw in the L4.01 software that needs to be fixed. IT causes needless duplication and it clutters the guide with redundantcy.
Good news L.403 fixed the search issues with the locked out hd channels in the higher range . So you can lock out all the duplicate hd channels in the 9000 range and the same for your hd locals too in the 6000 range , and it will now WORK with a search . So no more duplication !
Dish 522 picture qualilty
Newbie questions
