I have a dual-ouput Cband LNBF that is connected to two diseqc switches. One switch goes to a Coolsat 4000, and the other switch goes to an AZBox. No multiswitch.
When either box is switched to use the LNBF by itself, it works fine. When both receivers are connected to the LNBF at the same time, the signal on the coolsat goes out. I can't tell you at the moment if it goes out on the AZBox as well, because I forgot to check.
Anyway, this to me sounds like an LNBF problem, but I thought I'd fish for any ideas, known problems, etc before I go tearing everything apart looking for the source of the trouble.
Thanks.
Thanks.
