I just received what looks to be 2 new DSR922 One GI One Motorola without remotes
from a farm auction. the only problem with the one the clips that hold the front cover on where snapped, but a easy fix
the receivers look as they have never been used they power up with no problems the external buttons work just need to find a universal remote that may work
I have several here i will try to program in to see if they take
I have noticed that the LNB inputs have C/H and K/V will i have to use two Coaxes off the BSC621? and which Coax would be the KU band? The one marked receiver or the jumper side next to the receiver output on the 621?
does the DSR 922 support 13/18Volt switch over or do I need to go with another LNB with servo to go from V to H?.
How will the 621 work with the DSR 922
Would I be better just to run all my C Band on the BUD and then set me up a motorized Ku Band system as I have around 50 dishes various sizes from 18 inches up which i obtained from farm auctions over the years
Also I have a techsat system that i bought off barginland a while back with rather a Square dish and incased with 4LNB s
The receiver is a scart connection, but have alot of FTA receivers i can use or go with the other 922 i have.?
Im not sure this square dish would be of any use here in the US its only about 21 inches.
What would be the best bet to get the most of C and kU ?as to go with the BSC621 or do 2 different set ups all together and would the DSR922 do me better on KU Then one of my other FTA DBV Receivers if i do 2 set ups
