Yes, to both questions, Inno.
I have to have the 922 "on" and tuned to a vertical channel for the vertical channel reception. I also have the little blue servo box with the three wires.
Yeah, the SV360 does not have the connections to control the polarity. That is why the 922 is used. I forgot to mention that I am also using a high frequency splitter with the power pass to the 922, IIRC, without having to go to the living room and look.
Also, what is weird
now is I re-blind scanned a couple of the satellites for vertical channels (with the 922 on, of course) and found that if the SV360 blind scanned (let's say for instance that odd numbers are vertical) channel 3 on the 922, a few vertical channels scanned in. I saved those channels. Now, I blind scanned channel 5 on the 922---some of the same channels show up again plus one or two more NEW channels on the SV360. I save those for the heck of it. Then I blind scanned channel 11, some of the same channels show up again, some of the previous saved channels do not and then one or two more NEW channels show up. I save the channels again.
I chose the channels I want to save and eliminate the duplicates. If I view those channels from all the different vertical channels I scanned, I do not have to be particular which vertical channel I chose on the 922 to see the channels saved on the SV360.
I always thought that the SV360 blind scan was really good. It's just weird how this situation is working. I don't understand the why behind it or what is going on. But....
