I just found a DSR-920 for $1.99, at the 2nd hand store. The unit ID is still there! However, it looks like there is a separate VCRS unit in there as well. How do I check that unit ID? I found the diagnostics menu for the DigiCipher module, but I can't check the VCII + RS (less of a concern but more likely dead - says manufactured june '93). Also, anyone have a tutorial on battery replacement for these? I'm just going to work on the thing hot. I've heard one day your unit ID could be there, another be gone. I can't really tell, but it looks like the battery in the VCRS module (Blue Cage) has a slightly smaller Maxell 3.6v lithium solder-tab battery on it. I see a couple of test pads, one is "Test" and "VBAT". These would be easily accessible through the cage with 30ga wire to provide temp power until I can get the thing out of the unit, apart, and new battery soldered on. Does anyone have any experience with this? Wish it was a 922, but hey, for $2 I can't complain.
There is a "VideoCipher configuration screen - press 9" but when I do, says "please tune to a VCRS channel". I don't even have a dish yet, why do I need to tune to a channel just to look at the unit ID of the VCRS module.
Are the UNIT ID's of the DCII and VCII+ RS the same? I'd highly doubt it, as the VCII+ RS is in a separate side-car cage. I will need to solder temp power to it before removing from the cage (is it a problem to remove with the receiver plugged in? Otherwise I will need to temp-power the receiver mobo (which has the DCII chips), and it's covered by the VCII + RS module.
Sorry for the wrong post, if someone could at least tell me how to check the VCRS unit ID, to see if it's even worth buying a battery for that unit (as VCRS isn't used much anymore) let me know. If they know of the "VBat" pin even better, easy access to temp power, with line cord plugged in so I can remove without the possibility of losing the unit ID.
