2 months after my 622/Dish1000/DPP44 install it appears that my switch has died.
Got an error message telling me to do a check switch. That test only turns up 119 on port 1. If I swap out the DPP44 fo my older DP34 I see all 3 sats
(110/119/129) as before). It's the same on all 3 receivers. (622/522/322)
I've gone back and forth several time between switches, but always the same result. I wonder if there is even a remote possibility that the power inserter is bad or there is some other problem. Any comments would be appreciated.
The only downside of the DP34 is I cannot hook all three dual tuner receivers up at the same time.
yesterday I got a very nice (sounded stateside) tech CSR who has a replacement DPP44 on the way.
Ironically, at the install in early March, the tech could not make the switch work and left me with the DP34 installed. After he left I carefully traced all me cables with a tone generator and reinstalled the DPP44 and it worked fine. Now I am sorry that I told him it was ok when he returned the next day. With hindsight I should have taken the replacement DPP44 he brought back out.
TC
TC
