I currently have one dish pointing at 110/119 using a Dishpro Plus twin which is also connected to a second dish and DPP single LNB , with 2 lines coming into the house going to each dual tuner receiver. What are my options in adding a 3rd receiver. I was going to connect each respective lnb/sat loc to a DP34 then run 3 lines to the receivers, but I understand now that a DP34 does not work with a Dishpro Plus system, specifically the seperators that connect the 2 inputs at the dul tuner receivers. Is this true ? Is there any way for me to use this DP34...if not what are my options for the best setup ?
