Unfortunately when I had Dish Network installed at our home 4 years ago the installer did a sloppy job. We always had problems with the HD channels breaking up from 129 due to low signal strength. Last year I re-adjusted the dish myself and was able to receive higher signal strengths on all 4 satellites and the HD channels no longer broke up. Well now once again the dish got out of alignment during the winter and the channels are breaking up worse than ever before.
The installer ran four 50' strands of coax down to the DPP-44 switch which he mounted on the side of the house near the coax entrance into the house. The coax going to the power inserter is fairly short (roughly 10'). Now since the coax has been weather beaten during the last 4 years I'm thinking about replacing all the coax and installing the DPP44 switch near the dish using 3' or 4' coax from the LNB's to the switch and then one 50' coax down the side of the house for a cleaner installation. This would use less coax and provide stronger signals on all satellites. I will then use coax seal to protect all connections at the switch.
Question: Where do professional Dish Network installers place the DPP-44 multiswitch? I wonder why the installer didn't place it near the dish in the first place.
