Dpp+44 And Dp34 Switch
code10
I have a DPP+44 switch and a DP34 switch, can I add the DP34 to the additional switch outputs of the DPP+44? The goal is to get eight outputs, or am I just dreaming.
yes, but you won't get the 4th Sat. on the DP-34 receivers.
connect the 1st 3 "to additional switch" outputs on the DPP-44 to the Sat. inputs on the DP-34. The DP-34 will then be able to supply 4 recievers with those 3 Sat's.
Thanks for the quick reply. I will try it out, I just didn't want to burn anything up, my old 7200 won't see the fourth input 121 sat anyhow.
DPP44 and DP34
I asked this on another forum and others were concerned that the Power Inserter(although connected only to receiver port 1 of DPP44) would burn up the DP34.... I couldn't imagine why the power would go into the pass through ports, but just curious....
Has this been tested somewhere because I would like to do the same thing.
Thanks!!!
I've done it, it'll work fine...though I am sure you realize that you will loose visiability to 1 satellite on receivers connected to the DP34.
Jason
Thanks!!!
I'm doing it and it works just fine.
Jason
Specifically the 4th satellite, if you have one. If you only hook up 3 satellites to the dpp44, then you see all 3 on the dp34. Just wanted to clarify, didn't want anyone out there thinking you always lose one :p
Suggest Some Moveies Please!!!
921 Questions
