coinmaster32 said:As I understand it, the wind blowing across the dish generates a static charge, which must discharge somewhere, the only point then is the coax, which can fry the receiver. Grounding the dish allows any static buildup to go into the ground instead of the receiver.
I hardly ever ground or run a ground on an install I do or come across - it just isn't possible or makes sense to do with no ground located or on the other side of the house. I do them if they are pretty close and I can see a ground point but otherwise I don't fool with it as it doesn't hurt anything that I've ever seen.
coinmaster32 said:When Dish put up my dish on the roof, they didn't ground it.
Does it have to be grounded?
. The NEC was never rewritten for dishes, they are considered "antennas" (Like the huge old one used in the past). All you are really doing is creating an unapproved lightning rod by grounding the Dish.
How do you get around the QAS fails?
Installer here. I have been watching TV with an ungrounded system for a decade now. NO problems.
I think he works retail only. Probably not on the QAS hit list yet.
